Hey guys. What are the max feed rates that the r7 can do?
Hey guys. What are the max feed rates that the r7 can do? Just trying to set up my new machine parameters.
Thanks
I am pretty new but here is my two cents. Max scrolling around the table 1200 mm/min. The motors will go faster but for me it was hard to get the Y-screws to hold tension for long periods. I don’t cut any faster than 600 mm/min. That being said, I can run much faster if I am meticulous about setting up the screw tensions and block tensions. As far as Z goes it does not do much good to run really fast so I run about half of my XY speeds. Make sure the Z motor stays energized as it will slip. I energize all motors for 3 min but if you turn off your machine when not in use you can leave the motors energized all the time. Sometimes I fall asleep while the job is running so I don’t do that.
There is a place where people have published their $$dumps but I have not really looked for it. I would like to copy someone’s jerk velocities as I have not played with it yet.
thanks
