Hey, I am having some issues with Bluetooth in my program for my stranger things code. I want to have the option to run some patterns like Pride in my code, but when I run it in this code using ‘/’ for the if loop of Pride or a pattern, it doesn’t move and I have to keep sending ‘/’ for the pattern to move. When I remove everything from the bluetooth part it runs fine if nothing else is in the while loop. Does anyone know of a way to make the pattern work in this while loop? or have some experience on what I could change to make it work?
void loop() {
// Set string to incoming text
delay(10);
FastLED.show();
while (Serial.available() > 0) {
delay(50);
char inChar = Serial.read();
if (inChar == ‘’) { // Clear string using '’ input
fill_solid(leds, NUM_LEDS, CRGB::Black);
txtMsg = “”;
// erase the string so it doesnt print anything
//set all the leds off
else if (inChar == '/') { // Clear string using '*' input
pride();
FastLED.show();
else if (inChar == '%') { // Run other functions using specified inputs
blinkConst();
else if (inChar == '&') { // Run other functions using specified inputs
for (int i = 500; i >= 50; i -= 50)
blinkVar(i);
else if (inChar == '$') { // Run other functions using specified inputs
blinkRandom(50);
else if (inChar == '#') { // Run other functions using specified inputs
blinkRow(50);
else if (
else { // Other wise add input serial character to cleared string
txtMsg += inChar;
//blinkBlink();
printChar(txtMsg);
