Hey
I cant acces the “Configure tinyG settings” dialog. but a big blue text shows up saying, EDIT IN JS FIDDLE.
Any ideas why this is?
Hey
@Kevin_Hauser can u might help me out?
What workspace are you using, /grbl or /tinyg?
I’m using the tinyG workspace
do you have the skills to fix it? I’m worried to mess it all up:grinning:
Im having this problem also, im attaching an image of how it looks like. When clicking on the configure button, the hyperlinks Edit in JSFiddle and Result appear.
I never used that dialog box and configured TinyG settings via serial console. I have no idea whether this visual dialog option ever worked.
Simply use $$ to list current settings and then configure what is needed, one by one: e.g. $1tr=5 will configure 5mm travel per revolution for 1st motor (set to X axis by default).
Thank you Sebastian! Is there any manual with the serial commands available to configure the calibration settings? (pulses per revolution, travel per revolution etc)
EDIT: Found it myself, if its useful for anyone else, here is the serial configuration command list: https://github.com/synthetos/TinyG/wiki/TinyG-Configuration-for-Firmware-Version-0.97
Well it used to work when I first configured my cnc. But I guess I will be just fine the old school way
Also having this issue. I know how to edit the settings manually, but I’ve always liked this feature. Would love to see it fixed.
This config dialogue box feature still seems to be broken, I use Chilipeppr heavily on a daily basis and would love to see this gui fixed!!
Same here! Is there a fix for this coming anytime soon?
