hey I got a cr10s about 6 months ago and now it doesn't head
hey I got a cr10s about 6 months ago and now it doesn’t head up past 23 degrees. I have checked the connections but i can’t seem to figure it out. Any one that can help?
I had same problem becouse i turn off too quickly machine and heat cartridge died. I just change it and i works since. You can also change it and order ones with pin connector so you can easily swap it.
@Benjamin_Lukman so i change the heat cartridge?
@Chris_McKinstry yes if you have spare at home try it if this is not a problem then its maybe mosfet on board.
Hihttps://profiles.google.com/photos/116134710130856007925/albums/6567873497050310433/6567873495102575202
https://profiles.google.com/photos/116134710130856007925/albums/6567873693449767633/6567873693707512882
