Hey,
I wanted to pick up the question that has been stated a couple of times previously. Is there meanwhile a possibility to run multiple matrices/stripes of APA102 LEDs in parallel with FastLED? I am currently using an arduino DUE.
Best
Hey,
Best
You can use multiple outputs but there is no parallel output support yet for SPI based chipsets in FastLED. (So basically it will write one strip then the next, etc…)
In this case the writing time will for all the matrices will add up?
Yes - and generally hardware spi is fast enough that it will out perform parallel bit-banged spi output, which is why I haven’t put a whole lot of effort into it yet. (On something like the due parallel bit banged output will get to something like 8-10mbps aggregate data rate which is still below the 12-24Mbps you can get with hardware spi)
Parallel output is a thing that works well for ws2812 style LEDs because it’s base data rate is so abysmally low - 800kbps - so even if you do 16 way parallel output, that’s still less than 13mbps data rate in total - which is still lower than I generally run apa102s at.
Thanks a lot. Would it in this case make any difference if I chain them in line or give each matrix an own data line?
If you chain them in a line you can use the due’s hardware spi output - otherwise you’re bit banging which tops out somewhere between 3-5mbps. (There is a hack on the teensy 3.x where you can get four hardware spi outputs - but nothing like that for the due at the moment)
