Hey! I'm making a device that projects light depending on how much you move
Hey!
I’m making a device that projects light depending on how much you move in bed, in order to let you sleep faster. Now, for the prototype (and because I like to work in it) I use Max/msp for the interpretation of data, which sends one value to the arduino with led strip. Based on this single value, you’ll get either more or less lights projected.
Right now I’ve adapted the juggle(); from the demoreel to fit this need. However, it moves the leds in both directions due to the beatsin8. Is there any way to make sure the leds only move in one direction? I’ve found out this is more relaxing to look at in bed (waves going away from you).
void jugglemeter() {
// colored dots moving in both directions, amount is dependent on the received value
fadeToBlackBy( leds, NUM_LEDS, 4);
byte dothue = 0;
for( int i = 0; i < receive1; i++) {
leds[beatsin8(i+1,0,NUM_LEDS)] |= CHSV(dothue, 200, 255);
dothue += 8;
This is the function as I’ve got it now, with super low FPS (5) to make it nice and slow (I can’t find another way to slow down the pattern, but that’s a different question). The ‘receive1’ int thus varies between 0-20 (can be anything) for the amount of light.
Any direction you guys can give me to make it move into a single direction? Thanks a lot!
Maybe I’m not understanding what you’re trying to do, but if it’s only moving in one direction could you just use a normal “for” loop?
If you’re looking for something like beatsin8 that is BPM based but only goes in one direction you could try using beat8( BPM ) or beat16( BPM ). These generate a saw tooth wave that counts up and then starts at 0 again. beat8 gives 0 to 255, and beat16 gives 0 to 65535.
Example using beat8 to move a dot with a fading tail.
https://github.com/marmilicious/FastLED_examples/blob/master/beat8.ino
Ah yes thanks! beat8 did the trick. Now I see that it’s meant as beat+sin instead of ‘beats in’, haha.
Maybe I can achieve the same with 2 for loops within each other, as I need to be able to adjust the amount of dots chasing down the led strip on the fly (with the received parameter).
