Hey there - wondering if somebody can help out with this:
Hey there - wondering if somebody can help out with this: Is there a tool that will take an STL, align it with a print bed and save it again as an STL? Mostly concerned about Z axis alignment. THANK YOU!
Cura might too, I guess I’ve never saved it back to stl but it’s worth checking.
Awesome! Thank you! Any command line tools for this simple operation?
Openscad can import a STL
@netfabb Studio basic is a nice graphical program that can do this (and much more). It has a tool that will let you perfectly align any face of your object to the bed at z=0.
If you’re just worried about the object floating above the bed instead of touching it, enable Skeinforge’s multiply plugin - other modern slicers do this automatically. Slic3r will even let you export a stl file of a single part or a complete plate, with all parts touching the bed.
RepetierHost can do this.
Awesome. If somebody comes across a limited command line tool that does just this - holla! Thank you @Thomas_Sanladerer @ThantiK @Laird_Popkin1 and @Jason_Gullickson !!
