Hi All,
A little update,
We have been busy crossing the ts and dotting the i’s.
We have also added a few upgrades to the machine,
Ball screws have replaced the trapezoidal threads, and a Nema 23 now drives a HTD 3m closed loop belt for the bed.
The bed has been reworked to allow for fast interchanging. The blades can now all be removed as one unit, so switching between honeycomb, blades or rotary should be hassle free. The 20x40mm extrudes make for a great frame to attach clamps, custom jigs and alternative beds such as a rotary.
Speaking of rotary, we have added a 4 pin plug so you can already easily attach and detach a 4th axis motor without having to run a new cable.
The blades have also been reworked to provide better airflow and less flashback.
There is now a 24v 150w output plug on the right side of the machine, this is used to hook up the compressor allowing it to be directly controlled by the software/smoothie board.
The Pi 3 has been replaced with a Pipo x9s which is a windows 10 computer. It runs laserweb and other opensource control interfaces far better than the pi ever did. However, we have left the mounting holes for the pi in the electronics area in case you still want a pi as well.
Some other features of the new computer are:
8.9 inch touch screen, usb 3 ports, strong wifi so you should be able to reach your wifi hub even if your machine is in the back shed!
We have added a cooling fan to the smoothieboard. We never experienced any over heating but more cooling never hurt anyone.
There is now a choice of 2 locations to extract your air; left side and centre back.
Enclosed cable chain, to help keep the inside looking cleaner and dust free.
X axis servo future proofing.
Raster engraving is awesome but can be slow, so to future proof the machine we have provided the mounting holes on the X axis for a possible future Nema 23 servo which could increase raster engraving speed significantly!
Standard components are ordered and in the post, for the custom ones we are currently finishing off the 2D drawings, double checking everything and they will be ordered by the end of this week.
We will update the website in the coming weeks with more in depth information and the first kit assembled
Stay tuned.
FabCreator
Bonne
