Hi all, chemical question please.
I have organic growth/mineral deposits stuck to the glass inside my laser tube.
it allows air bubbles to have something to attach to and so my tube is always full of miniature air bubbles.
Most likely caused by a) me not having changed the water for several weeks (not that long I wouldntve thought) after installing machine, or b) using deionised water instead of distilled water.
I’ve since replaced 10% of my 15 litre water tub volume, with Methylated Spirits (ie. ethanol with a little methanol) and this hasn’t dissolved it.
Should I increase the methylated spirits volume to something more potent, say 30, 50%? 100%?
At what point is too strong that the rubber?/silicon water tubing / glue / connections of water tubing to the laser will dissolve away and spill water into my machine killing it and me.?
or is there a safer chemical to flush through the tube that will dissolve these deposits/growths that are seemingly stuck…
is it maybe a better idea to drain the system and let the tube dry out and then maybe use pipe-cleaners to scrub the inside of the water jacket inside the tube?
god I just don’t know haha. alls I know is I want to clean the inside of my tube.
