Hi all,
First congrats on FastLED, was able to switch to it from NeoPixels without much effort. In face I can switch between the 2 libraries using a pre-compiler directive.
However I do have a problem. I am using FastLED with the SdFat, UTFT and URTouch libraries. When the touch screen is touched (from a menu presented on the LCD), a LED sequence starts and when the sequence is completed it should return to menu and wait for commands.
However it does not return to the menu. I traced the calls and the code does go through the part where it’s supposed to write to the screen, but it does not change.
If I switch back to NeoPixel library, the code behaves like it should and after the LED sequence it returns to the menu and LCD access works.
Any clue ?
Thanks.
