Hi all,
I’m new here in this forum.
I recently ordered a simple pcb milling machine from ebay. The apps I found on the net, to do the milling, was quite primitive and unflexible. Until I found ChiliPeppr. Exactly what I wanted! One tool for the entire process, and developer friendly too.
As my machine has an integrated grbl based controller, I used the grbl workspace and then moved to jpadie to match grbl 1.1. I got my machine working. But to get a simple pcb done was a struggle. My experience in one word: unreliable. So, as I am a web developer, I checked out how to debug and discuss the problems with you - the community, or maybe fix them myself.
But with the grbl or jpadie workspace, I found no way to trace the code I run back to a version in git. Neither the workspace nor the widgets have the commands Fork in github, that can be found in the tinyg and sample workspaces. For the widgets I can fork in jsfiddle, but not for the workspace.
So I have an unreliable workspace with unknown code origin and version, that I may play around with. But what should I do with my fixes?
Or is there a safe way to find out the origin on github of the code I run?
I really appreciate how simple it is to hack away with the code, but I would prefer to put my results of this in a github pull request, as is the normal process for most open source projects.
