Hi all!
I need to print a part in ABS, and soluble support material is needed to be able to print the part correctly. I’ve been testing E3D Scaffold filament with it, but ABS and Scaffold doesn’t really stick to each other (as E3D has stated, but I still tried it).
HIPS is often said to be good support material for ABS, and it should dissolve with limonene. However I’ve also read, that usually the ABS part itself gets damaged before HIPS is even softened, or if low concentration limonene is used it takes ages to dissolve the HIPS at all.
My question is; is there any soluble support material for ABS plastic that really works? Or if you have any other idea, you are welcome to suggest!
