Hi All
I will be controlling my FastLED project via DMX. It will use the latest library running on a Teensy3.2.
My question is how to control the intensity. In the DMX world intensity is byte parameters with an absolute value of 0 to 255. I will be getting this value and then I want to change the brightness of the led display to that. So I need to set the absolute brightness value.
The FastLED brightness methods only seems to allow reducing the rihtness by a portion of the current value, which is not how DMX wants to do it.
Is there a way to accomplish this? Bear in mind that even when reduced to 0 (off) it should be ably to set the value to another value (from 0 to 255) and the display needs to get back there.
