Hi all! It's me again :) as I said earlier ( https://plus.google.com/+JarekSzczepanski/posts/MLTxKWexDeM ) I'm
Hi all! It’s me again :slight_smile:
as I said earlier (https://plus.google.com/+JarekSzczepanski/posts/MLTxKWexDeM) I’m going to cut top&bottom plates from 3mm aluminium.
I prepared DWG files based on files from @Benjamin_Groves and latest parts from Grabcad. They are ready to sent to water-jet cutting. Anyone could look at them and spot any obvious mistakes? :slight_smile:
Changes: holes are 3.1mm (instead of 3.5mm) and top plate is slightly longer because front differential is mounted flat
Hi, I wonder what is the cost of cutting those parts? Mabe you have some more cost calculations for other elements?
I’m getting more and more interested in building rc car:)
I think I should made it (top&bottom plates) for around $20-25 (alu 3mm, waterjet)
