hi all ! trying to find ws2811 led strip, 60leds/meter, 5m, ip67, individually adresable (not 3 by 3), 12 or 5v. I checked on alibaba but they are either super expensive, or 3 by 3. Would like it either delivered to France, or to Singapore (depends on delivery fees). Do you have any suggestions please ? (with direct links, as some vendors have pages and pages of products, and I don’t find alibaba easy to filter and find) Thanks in advance !!
I’ve had success ordering from Ray Wu’s store on aliexpress. http://tinyurl.com/raywu
Thanks Mark. Yes I came to his store when looking for past/similar question on this group, but couldn’t find the right ones as the store is HUGE! Which one did you order ?
Here’s a list I had prepared some time back: https://docs.google.com/spreadsheets/d/1bPEHKI-EDkCgUmxFcMM_O_mis_gugL0QtthsZoD5F-g/edit?usp=docslist_api
wow this is precious ! thank you !!
The individually-addressable strips are called WS2812, not WS2811. WS2811 is the separate chip which is used to drive groups of three LEDs.
…this explains a lot hahaha. Thanks for the info ! any details on major difference and pros/cons between 5v/12v ?
@Michel_G_Khoury , it really depends on your goals and power sources. Larger installations benefit from 12V strip because you can space your power connections farther apart (because the higher voltage allows for more watts per amp). Some animations, particularly slower ones, won’t look as good on the 12V strip because they’re only addressed in groups of three.
I ignored that and used 5V strip for the Tripper Trapper (a 10m long, 3m-wide tunnel) because I wanted the tighter 1-LED resolution, and while it is possible, it adds a lot of complexity – especially if your main power source is already 12V (as it was with the Trapper’s solar storage).
@Michel_G_Khoury hi ws2812 is use ws2811 IC but can individually controll, if you buy from Chinese factory directly, it’s very cheap. for 60led/m ip67, only need $6.25. it’s 5V
Hi @Tan_Linda ! Thanks for sharing this info ! do you have a link or anything ? I am currently in Singapore ! Thanks
@Michel_G_Khoury link is http://www.sfleds.com, you can add my skype: shiningfor2, or send me a email:linda@sfleds.com
I can send some pictures to you
