Hi, can anyone confirm if this is ok to use on the cables on
Hi, can anyone confirm if this is ok to use on the cables on the tube ?
Servisol Silicone Adhesive Sealant:
Ready to use, one part• Neutral cure, non-corrosive• Suitable for use on metals and plastics• Excellent insulating and sealing properties• Prevents arcing on EHT connections• Tack free in 40 minutes• Operational from -50°C to +230°C• Ideal for potting electronic components and keeping gaskets in place• Supplied in a 75ml tube
I just read this link, see if it helps you decide if it is ok to use.
@Steve_Clark
#K40Silicon
Seems to work well. No arcing.
@Frank_Farrant are you saying that you did nothing else but put new silicon on it and now its not arching?
Is your machine running again?
I changed the tube and used the Silicone I bought and all is great now. Adjusted and cleaned the mirrors and she cuts like a dream.
Many thanks for your help over the last few days.
@Frank_Farrant I am happy for you but shocked that the arc was simply the silicon??
Never cease to be amazed at the K40…
@donkjr I think the tube that was arching had a fault as after I removed the cables from it, I could see that the round metal clip under the Anode was loose. It’s on its way back to the supplier for a refund.
@Frank_Farrant Ah, I missed that you put the other tube back. Now it at least makes a bit more sense.
Could you try and take a photo of the portion you thought was a fault. We can use for future reference.
