I want to build a Philips Hue-ish Strip clone with mysensors or esp8266/mqtt. To drive my 5m RGB (non-smart) with FastLED I bought a driver board with 3 FETs and a P9813. I am able to show desired colors. To smoothly blend between the colors, I ended up using nblend. The third parameter is the percentage of blending as far as I understood. It is type hinted as fract8 which is a uint8_t, right? So, I expect to linear blend from color a to b while incrementing the third parameter from 0 to 255. What I observed is, that the blending is already done by i<50, resulting in counting to 255 without further effect. Can somebody explain this to me?
