Hi Community,
i’m from germany. Can i buy Eustathios Spider V2 as KIT?
I am very impressed by the printer.
Thank you
Hi Community,
Thank you
There are no full kits available (it would really cool if a company put one together). But all the source files are available, and the BOM if pretty detailed for sourcing the parts yourself.
There is an Extrusion kit available from @Makeralot ( https://www.makeralot.com/20mm-x-20mm-extruded-aluminum-for-eustathios-3d-printer-p207/ )
https://www.makeralot.com/20mm-x-20mm-extruded-aluminum-for-eustathios-3d-printer-p207/).
For the frame there is a local supplier in D called motedis, I used their 2020 type B profile for my Eustathios, you can order pices cut to lenght but you need to drill holes and cut threads yourself. Dold mechatronic also has some mechanical parts like 8 and 10mm colomns (Wellen).
@Daniel_F
Hallo Daniel,
vielen Dank für die Info. Hast du evt. eine Liste, wo du die Teile in Deutschland gekauft hast.
Vielen Dank für die Antwort im Voraus.
Grüße Bat
