HI Do you know how I can print the first 30 Layers at one
HI
Do you know how I can print the first 30 Layers at one speed and the rest of the print at another speed ? Using Slic3r or Cura. ( Mendel90 )
Thanks
Slice 2 gcode files, same settings except for speeds - Then calculate what the 30th layer would be and splice them together by deleting the first 30 layers from one file, and replacing them with the first 30 layers from the other file.
Gcode is completely human readable.
Have you tried using the tweak at z plugin in cura? I think it can do that.
Thanks guys, I not familiar to the Gcode editing but will give it a try to change it.
I also have a look at Cura and see how to use the plugin.
The tweak at a plugin allows you to pause the print at a certain a height, fix something on the print, and then resume.
Can’t you use different profiles for different z heights in Slic3r? If not you can cut the part in two in Slic3r, and not move them, then run a different profile on each part.
Btw this will also work and doesn’t require separating your model: http://slic3r.org/blog/modifier-meshes
