I am currently learning how to work with FastLED to add some mood lighting to my house. I am using a nodeMCU that gets it’s commands from an MQTT topic from Home Assistant, that part works like a charm, just like setting colors etc but the colors are now chaning instantly. I would like to achieve a crossfade when I change colors, I can probably get it done with some loops left and right but I also noticed the blend functionality.
I am no programmer but can find my way around programming pretty well but could not find any documentation (that I can understand) on how to use the blend functions. There are a lot of basic tutorials on how to get started but no detailed tutorials on more advanced functionality, at least none that I could find.
Can somebody point me to a decent tutorial or examples that I can use to figure out the more advanced functions (especially the blend function)?
You can use RGB or HSV with blend. The two colors to blend are followed by a 0-255 value which determines how much of each color is used (ie. 0 = all colorA, 128 = 50% of each, and 255 = colorB completely overlays colorA).
If using HSV you can also specify how it goes around the color wheel toward the second color by using:
BACKWARD_HUES: hue always goes counter-clockwise
SHORTEST_HUES: hue goes whichever way is shortest
LONGEST_HUES: hue goes whichever way is longest
(The default is SHORTEST_HUES.)
