I don’t know how this started, but suddenly whenever I open the grbl serial port, the grbl re-sets continuously.
I can’t do anything, and all I see is the grbl welcome message in the console, and the GRBL Widget’s message:
GRBL has been reset - temporary work coordinate and tool offsets have been lost.
Serial Console shows this again and again:
{“Cmd”:“WipedQueue”,“QCnt”:0,“Port”:“COM5”}
{“P”:“COM5”,“D”:“Grbl 0.9j [’$’ for help]\n”}
When opening the serial port outside of chilipeppr/SPJS (using arduino’s serial monitor for example), grbl behaves nicely (i.e. starts and runs normally, responds well to all commands).
I tried a different arduino, same results. I tried a different computer, same results.
There was nothing else on screen other than what I’ve described. Even the serial console log was exactly what I pasted (only again and again).
Eventually, I figured it out. For future reference - the problem was corrupt configuration of grbl, I’m not sure how that affected the second arduino, either coincidence, or we did something to both…
The grbl re-set itself whenever ‘?’ was sent (which is why it didn’t happen when working through other consoles, they don’t auto-send ‘?’)
Do you guys think it is worth it to put some code into the grbl controller to detect this reboot-loop and gracefully alert the user that there might be an issue that requires a $RST=# to be set?
