donkjr
(Don Kleinschnitz Jr.)
May 2, 2017, 7:56pm
41
@Camarda_Neon_Salerno Sorry I was trying to understand the symptoms better and insure that I was not confused as something does not make sense to me.
Conditions under which the current is UNSTABLE when you push the "Test " :
A. The machine wired normally
B. The pot connected directly across the LPS 5V-IN-Gnd with the control panel disconnected from those pins.
Conditions under which the current is STABLE when you push the “Test” button:
A. When the IN pin is shorted to the 5VDC.
Is the above correct?
In 1.B is the current unstable in all positions of the pot?
+Don Kleinschnitz
Exactly all the points are right.
I was thinking it could be a flyback problem?
donkjr
May 3, 2017, 4:00pm
43
@Camarda_Neon_Salerno at this point I wouldn’t doubt anything but it does not make sense. Meaning if it was the flyback it would have intermittent operation irrespective of how the IN gets its voltage, i.e. by pot or pulled to 5VDC.
I think there is still something else we are not seeing?
+Don Kleinschnitz
Do I have any idea of some component on the main plate?
donkjr
May 4, 2017, 1:03pm
45
@Camarda_Neon_Salerno Sorry I do not understand the question.
