hi everyone just loaded laserWeb to use with my tinyg v8 on my ox cnc for plasma. nice to have a place to go fo rguidance.
Haven’t done it yet but plan to soon.
hi Don just working on mine now. learning to wire a mosfet as a switch from my pwm on tinyg to turn on plasma. I have no idea what I’m doing but try try try …learn learn learn lol
@Darrell_Hoath what are you trying to do I may be able to help with the mosfet?
I have a n mosfet and I’m getting 3 volts from my pwm pin on my tinyg when I run a small cutting job on laserweb I need that pin to trigger the switsh on my plasma cutter. but I’m not sure how to wire the mosfet.
I found the wire going to the trigger on the plasma. basically I need a 3 volt relay
Are you just trying to turn the plasma on and off or control its power?
Can you tell me more about the plasma and its trigger?
You would not want pwm running a relay (to high a frequency and lots of noise) but just to turn it on and off we could use a mosfet in open drain and that would work from an external voltage.
hay guess what when I got my Arduino I picked up a 37 sensor kit from elego and there is a relay sensor module in that works great lol
@Darrell_Hoath will you be running the relay at PWM speeds ;)?
nope spin on off
how do you set the tabs?
@Darrell_Hoath “tabs” ???
It has a place where you can pull your file down to add tabs but that’s all it does there is no way o set them
