Looking for advice on eliminating warping/liftup of large, flat parts:
This is for printing multiple sets of 3DR delta reprap parts (by +Richard Horne )
PLA on an Ultimaker , on blue tape
the parts seem to lift up close to or at the edges of the blue masking tape (the parts stick well to the tape, but the tape itself with the part lifts up)
Perhaps some wider masking tape can help ? (if so, if anyone has a good source for very wide blue tape in Europe I would be thankful).
If there is some other method (other than heated bed of course) , I would love to hear it
I use abraded Kapton tape on glass and a brim, I regularly print items 200x150x150 with filleted bases and this is the only way I’ve found to keep them down.
On particularly difficult prints, I print 0.5mm high 20mm circular pads (some call them bunny ears) on the corners of the model, pause the print once the pads are printed and kapton tape the pads down before resuming the print. It’s a pain, but it works well!
@Jesper_Lindeberg ooh ! thanks I totally forgot about brim ! I deactivated it a while back as it was taking ages, but it might just do the trick !
@Mohamed_Thalib_H thanks ! That would be good, unfortunatly , glass panes the right size are very expensive, but I might give that a try on my reprap (which already has a glass bed
@Marcus_Guin_Klutmann good catch ! I have not cleaned the platform in a while, that might help as well
@Mark_Durbin even if it sounds clunky, the trick with the circular pads might help as well , and could potentially use a lot less plastic / require less cleanup: thanks !
Do you use “sticky” Kapton tape ? (if that even exists ?) Way back with my first reprap I always printed with kapton, but I have some very bad memories of it
@Mark_Moissette_ckaos Just normal Kapton tape, I have some nice wide stuff, I use a nylon scouring pad to abrade it slightly and clean it with isopropanol. it lasts for weeks.
What qualifies as wide blue tape in your book? I use 5cm wide one I found after much searching at voelkner (dunno if they deliver to france though in an affordable way)
after you’ve applied the blue tape, but the glass in the oven on low for a bit. this seems to help set the adhesive on the tape to the glass after it’s cooled.
@Mark_Moissette_ckaos make sure to use hexagon fill if you don’t already, this gives more strain relief for contraction. Rectilinear fill always rips my part corners off the bed
