I generate gcode from eagle.
And video: https://photos.google.com/share/AF1QipO5G5qxsQ7O_XSQERp9vaUEP7An_-KjkYHAggJnCETP0Ff6fddM5g6IjgRHPQ7vMg?key=S1d2cHdMajM1NTEyVm1PNmkxdVJGSlNRQUJPTk5R
Version 5.6 published with @ameen.nihad 's changes to round to 4 decimal digits. Hopefully this fixes the problem you saw.
Thanks a lot for that. Working great now. Here is a board I just made. Came out pretty well. I can see how an end mill cuts much better than a v-bit. Unfortunately I only have a 0.6mm end mill at the moment however I have a 0.3mm one coming from China. As you can see I have a few sections on the bottom where I didn’t go deep enough as I set the depth to 0.07mm. I’m still quite impressed with the result.
