Hi Folks,
I have decided to take on building a delta from scratch and was wondering how the community felt about some of the available features. I’ve seen arguments for and against each of these and I was hoping to get some feedback from actual users before committing myself to one over the other. So here it goes:
linear bearings on rods vs v-slot track or some other alternative?
Belt driven vs some other alternative, I’ve seen something that looks like string or fishing line.
Frame: is a frame of aluminum extrusion sufficient, or should it be braced with something more stout.
I’m aiming for a build envelope XY of about 200-250mm, square vs round build plate? Does it even matter?
Bowden vs direct drive?
Electronics: I have the arduino mega 2560/RAMPS 1.4 combo that I was going to use for this, any thoughts on alternatives/drawbacks to this combination?
I welcome any other insights you might be able to offer someone preparing to transition from a traditional Cartesian bot to a delta. Any tips or tricks you might have seen in your own build that I could be forewarned about would be greatly appreciated.
Cheers
