Hi Gang, I’m wondering if anyone has recommendation on a dc motor control chip, compatible with the low IO voltage of the ESP (logic high <=3.0v)? My motor is 7 amps peak, 3 amps nominal (big fan motor). I need direction and an enable pin that’s compatible with pwm for speed control.
I found a few chips that do this, but their logic high is >4.0v. So I’d need to put in a level translator, and also a second power supply. Rather stick to a single power supply to keep the board small and simple.
Any ideas?
