After upgrading to the latest Marlin RC im having issues with my VIKI-X3.
The problem is with the encoder button, when i press it, it goes back to the previous menu, looks like a double press. If i race the encoder wheel i can navigate the menus.
Its the same as described on this bug:
but the proposed fix doesnt work.
Is anyone having the same issue?, im willing to test code and all.
also the g28 has some problems, its not posible to use a delta printer because you need to press the A and B tower’s endstops. Otherwise the carriages dosen’t go home at same time
I find with mine it sometimes jump to the previous option when i click. Previously it used to jump to the next menu anywhere from 1 to 4 clicks, so I know that’s what they tried to fix. There is a setting in the config file I saw it when I loaded the new firmware but haven’t bothered looking for it since.
