Hi guys, I am using freeCAD to design  3D model for 3D printing,
Hi guys,
I am using freeCAD to design 3D model for 3D printing, but I don’t know how to change the file format to format STL. Could any one guide me to that ?
You need to export the file. Choose Mesh Format from the file type drop down. You can specify .stl as the file extension but I think that is the default mesh format.
I tried ,but it did not work. Thanks Neil Darlow
Neil Darlow, it is working now . I just need to select final object then export it
I just did the same thing. you must first select the right object to export in the “Model” tab. Than you can export. I had to try 3 times before I was successful
