Hi Guys,
i have a little problem on my BBB. I flashed the following image: BBB-eMMC-flasher-2013.06.06.img
But i can’t find an /etc/network/interfaces file
Whats wrong?
Hi Guys,
Whats wrong?
your flashed without errors?
waht errors?
I had no errors
Connman is used for handling network connections, so /etc/network/interfaces should not matter. I do have that file, but it is not used by connman.
@Elias_Bakken thanks. That was my problem
problems are solved yet?
CCan someone point me to a simple setup of conman on the BBB that will enable WiFi connected to an access point with WPA2 security?
When I plug in my wifi adapter, I can see wlan0 in the ifconfig -a results, but it’s down. If I try to “ifconfig wlan0 up” I get error messages.
