Hi guys ! I have two question the first one is I will building
Hi guys ! I have two question the first one is I will building a project using 800 RGB LEDS ( WS2812B ) and i need in a full brightness every leds what should i used power suppy ?
the second one is can i used FastLed library and adafruit in the same sketch ?
like this
#include <FastLED.h>
#define NUM_LEDS 54
#define DATA_PIN 6
CRGB leds[NUM_LEDS];
#include <Adafruit_GFX.h>
#include <Adafruit_NeoMatrix.h>
#include <Adafruit_NeoPixel.h>
#ifndef PSTR
#define PSTR // Make Arduino Due happy
#endif
I will use adafruit for matrix and i will use fastled for animation with 24 bits color
because adafruit matrix only supports 16 bits . Thanks in advance for answeing my question sorry for wrong grammar :smiley: :smiley:
800 * 60 mA * 5 V = 240 W. Libraries are not compatible, both try to use the same resources of your Arduino at the same time.
800 LEDs will be around 60A at full power
And you want my lib instead of adafruit http://marc.merlins.org/perso/arduino/post_2018-04-23_FastLED_NeoMatrix-library.html
You can also do 24bit color with the adafruit lib using the color passthrough hack in the library
Add 25% to the power supply rating, so if you need 60a use at least a 75a supply(s)
Thanks guys you help me a lot , my project is displaying a Text and animation using RGB LED Strip with GSM module .
@Marc_MERLIN thank you bro , you’re blog is awesome :slight_smile: i have a question bro
FastLED_NeoMatrix *matrix = new FastLED_NeoMatrix(matrixleds, mw, mh, mw/8, 1,
NEO_MATRIX_TOP + NEO_MATRIX_RIGHT +
NEO_MATRIX_ROWS + NEO_MATRIX_ZIGZAG );
can you explain the 4th and 5th parameter , why you divide mw by 8 and what is the next one parameter
@jester_salivio this is the same syntax is neomatrix. Did you read https://github.com/marcmerlin/FastLED_NeoMatrix/blob/master/examples/MatrixGFXDemo/MatrixGFXDemo.ino#L62 or equivalent?
mw/8 is 24/8 =3 columns, followed by 1 for 1 row.
Couple of math corrections… 800*.061.25(margin) = 60amps and 60a5v =300watts… if you want margining on wattage look up 350watt which falls pretty close into the PC ATX line of supplies… :slight_smile:
@Marc_MERLIN thanks man
