Im trying to setup a laser diode on a router, all controlled by an x5 mini (v1). I can move x/y/z ok.
Im failling miserably trying to control the laser. Im using a chinese (bangpod) diode with its driver. If i use a cncshield with grbl it works ok, but when i try to use it on the x5 mini, i fail.
from my config.h:
extruder.hotend.enable false
laser_module_enable true #laser_module_pin 2.4
2.4 is the extruder (on the x5 mini). If i connect the pwm signal cables the psu gets shorted. Same happens if i connect it to the fan pins.
@Nicolas_Arias I would need to know what circuit it is driving, not just the wiring, that’s why I was hope-ing for a schematic of the driver.
Can you point me to the place you got it?
