Hi guys  ! ive worked out that i can swap an old coreldraw 12
Hi guys ! ive worked out that i can swap an old coreldraw 12 to corel x7 (2014) but i have meet a problem :frowning: my laser cutter wont to use the whole workspace… all staff what i draw is being moved to the top of the workspace like using just top half of workspace. anyone got some ideas ? im very new to lasers by the way :smiley:
Definitely points to a Corel issue. I have X5 I think (although I just ordered the X8 upgrade - supposed to be some very nice stuff in there). It’s got to be something with the plugin they install.
I have corel x8 with the M2 nano board. At first I had a ratio issue similar to yours. Make sure anytime you adjust properties(print size,dpi,etc), you do it through the engrave tab, as it acts like a universal change. If you change properties thru the cut tab that are different from the engrave tab -that’s when your ratios get out of whack(thru my experience). If I’m only cutting, I make my changes in engrave and verify them in the cut properties. I do this with every job and haven’t had issues. If you are still having issues let me know and I’ll screen shot if need be
im preapering myself for holiday and i havent got time for a machine but when i find a spare min i wil have a look into those settings again
very big THANKS guys !!
hope that you will enjoy your x8 Jim :slight_smile: ive tried it and i have found that work i soo much easier :smiley: good luck !
