Hi guys just got my new LO mirrors and installed them aligned the mirrors and did a test on cutting 3MM pop ply can’t cut it unless i really crank up the power i checked the lens focal length,checked the tube,light is coming right down the center don’t see any problem there but i did notice something when i did an alignment the beam made 2 dot’s on the target and i can’t figure out why
Lens in the correct way? Any water or dirt on the final mirror or lens?
Jim Thanks for the response brand new mirrors from lightobjects gold plated version, i pulled out the lens and double checked it for proper convex concave orintation bevel side is up per forum
The 2 spot thing suggests an aberration that’s splitting the beam. Either on the lens or the nozzle. I just did the LO upgrade myself but am okay. I have had the 2 dots issue caused by a water (actually alcohol) when I was cleaning it. Once it evaporated & I wiped it for good measure it cleared up the problem. If it’s not that or something like a metal burr in the nozzle aperture then it would seem to be a lens aberration. You’ll want to talk to LO about that.
the lens is orignal you think it could be the lens itself
so just looked at LO and they don’t offer a12 MM replacement lens
I upgraded the head at the same time and while I was at it the lens (18mm) too
Starting at the source do you have the 2 dot issue anywhere else? Either using a piece of cardboard or a piece of tape or sticky note on each mirror starting at the one in the back with the laser (the fixed mirror) then the Y-Axis mirror and then the X-Axis (laser head) one. If all of those imprint a clean hole then the aberration is being introduced at the final mirror or lens. To figure out which, take off the lens and run the laser shot to see what it looks like unfocused - still should be round & a single spot.
I prefer cardboard or a 1/4" plywood piece for this test because I don’t have to worry about burning through the paper or tape and not getting a clear reading. The plywood is going to be able to take a sustained test shot at say 10ma which should tell you if you’ve got a clean circular spot.
Wherever in the chain you get the double spot is where you’ll know is the problem - the last optic that’s directing the beam before your test ply.
Jim
OK thanks for that i will go and give a test right now
Dennis
I just had the 2 dot issue a few days back. Mine also were oval shaped, instead of circle. Turned out my alignment was quite off (since I was moving things & testing things). It seemed to be the final mirror for me. Also, I noticed in amongst all this that cleaning mirrors & lens with water works better than using methylated spirits. Methylated spirits kept leaving weird marks on the mirrors/lens that looked like it was burned. Once I washed them with water they were nearly perfectly clean again.
