Hi guys, made a new version of my music controlled led strip and thought you might like it. It is kind of simple effect but I think it visualizes the music nicely!
I will add source code later on to video, but I also have one question - would someone have good idea how to make the speed of led slower towards the end of the strip?
https://www.youtube.com/watch?v=B9r-eKI2_KE
Slowing the speed down near the end of the strip would be a challenge. Something much easier would be to fade the lights out as they get closer to the end.
@marmil Yeah I thought so too. I might try fading them, could look even better!
If you slow them down toward the end, the lights will probably have to merge/stack up. Difficulty and efficiency will probably depend on how you’re tracking the pattern progression, but I assume you’re (essentially) shifting new values into the front of an array on each trip through the loop, copying the value at position N to position N+1?
Maybe you could try scaling the new position. Maybe using something like:
// scale movement to about 95%
scale16by8( N, 242 ) + 1;
But again, depending on your current code, it might not be as simple as that.
Dougal’s comment reminded me of an easing sketch I wrote ages ago:
See my code for catenaryBT2, slows LEDS using a sine function.
