Hi Guys need some help i am looking at thesoftware on my supplied cd and i don’t see coreldraw on it i see laserdraw, Winsealxp,corellaser, that’s it is winseal the chinese version of corel draw
thanks
Dennis
this is what i find on the cd thanks for any help
LaserDRW¡ª¡ªfor making stamp
CorelLASER¡ª¡ªfor artcraft engraving
WinsealXP¡ª¡ªfor making stamp
note: you need install CorelDraw 12 or even newer version, then, you can install CorelLASER
You can use CorelDraw/Laser to make anything, you do not need the other programs
So i just install laser draw and that’s all i need if so then to install it would i first install the dongle key then the program i don’t see any drivers on the CD are they in the program install
Thanks
Dennis
No, the dongle key has nothing on it. It is just a hardware key, to enable the laser. If you don’t have it plugged in, you won’t be able to use the laser.
https://drive.google.com/folderview?id=0Bzi2h1k_udXwUWJwM29COUNxSUU&usp=sharing
This is the K40 software (~690mb).
You will find in there CoreDraw12.rar (spelled incorrectly). You may find your disk has the same, just may have overlooked it because of the incorrect spelling.
Basically, install the CorelDraw12 from the .rar file. Then install CorelLaser. I can’t remember if anything else was necessary to install (USB drivers or anything like that maybe?).
First off many thanks to all of you who on this forum hellping others strugling to get there machines up and running Thanks Yyysuf i will give that a try.
Dennis
