Hi, Have been working on this for a while. I’ve got all the hardware side of things completed now, but had to give it a quick test to see what it was like. Currently running the lava colour pallette.
Wow, you just up’d your home’s value! How many LEDs are you controlling and with what are you controlling it with!?!?
pretty cool! (oh, maybe HOT)
What is the hardware set you’ve used?
Yeah, don’t tease! It should be mandatory to spill the beans on the pixels/power/control setup when posting pics of an installation this size
Sorry
haven’t actually counted all the pixels yet, I just cut them to size as I went. A quick estimate would be about 420 pixels 1260 leds (60 leds/m 20 pixels/m) running off a 12v 20A supply.
as for the controller setup its split into 6 “legs” which were stuffed into one output on the mega for the purposes of getting it all lit up!
Just in the process of re connecting as I have a couple of white balance issues.
Re: white balance, you’ve seen the color temperature setting code/options in the 2.1 library, right?
thanks yea, just re acquainting myself with it all. The last time i delved into the software side of things was pre 2.1.
I ordered the first 5 metres just to see what it was like and if it would work as i intended, bought the rest some months later from the same supplier and it came from a different batch
Over estimated the LEDs slightly - 347px 1041 LED.
