I am currently using the Bean+ board and trying to control some NeoPixel with FastLED library but im having the belows compilation error. I know that the Bean had similar problem before and has been fixed. Is there anything I can do to jump pass this error?
Thanks in advance.
\Documents\Arduino\libraries\FastLED-master\FastLED.cpp: In member function ‘void CFastLED::delay(long unsigned int)’:
\Documents\StudentHome\Group45$\n8628645\Documents\Arduino\libraries\FastLED-master\FastLED.cpp:133:9: error: ‘yield’ was not declared in this scope
yield();
exit status 1
Error compiling for board LightBlue Bean+ (2.0.0).
Bean needs to add a definition for yield into their library to be compatible with the rest of the arduino world. In the meantime, you can work around this by adding the line:
Do you have any other boards (Arduino, Teensy, etc) that you can test the same setup (LEDs, power supply, wiring, etc)? Just trying to eliminate the Bean+ as the source of the issue.
Sorry I didnt have time to spend on this project and just manage to get some time back on it.
So I have tested the setup with a Uno and Bean and the FastLED works as expected. However, using the Bean+ (another variant of the Bean board), it compiled now but nothing is lighting up.
I know that the Bean+ pin mapping is different to Bean. Could that be the reason?
