Hi,
I am happy to have discovered the fastspi2 library, but run into some problems when trying to compile the fast2dev example for the teensy 3, which I get to work fine with an Arduino Uno.
I suspect it is something very basic (I am new with the teensy 3, but have used previous teensies for led strips before). Is there something I need to add/modify to get the fastspi2 library to work on the teensy 3? After not getting it to work I copied the fastspi2 library into the library folder inside the Arduino.app where the other teensyduino libraries are, but this didn´t seem to change anything.
Below is the long error report, if that helps.
hc
Arduino: 1.0.5 (Mac OS X), Board: “Teensy 3.0”
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mcpu=cortex-m4 -DF_CPU=96000000 -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -mthumb -nostdlib -D__MK20DX128__ -fno-rtti -felide-constructors -std=gnu++0x -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -I/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2 /var/folders/Gi/GiTf5ITdHWm++psK9TEs5++++TQ/-Tmp/build1713018055754262571.tmp/Fast2Dev.cpp o /var/folders/Gi/GiTf5ITdHWm++psK9TEs5++++TQ/-Tmp/build1713018055754262571.tmp/Fast2Dev.cpp.o
In file included from /Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi.h:45:0,
from /Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/FastSPI_LED2.h:6,
from Fast2Dev.ino:10:
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::Write<CONT_STATE, WAIT_STATE, LAST_STATE>::writeWord(uint16_t)’:
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:232:41: error: ‘SPI0_PUSHR_EOQ’ was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:233:41: error: ‘SPI0_PUSHR_CONT’ was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:234:34: error: there are no arguments to ‘SPI0_PUSHR_CTAS’ that depend on a template parameter, so a declaration of ‘SPI0_PUSHR_CTAS’ must be available [-fpermissive]
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:234:34: note: (if you use ‘-fpermissive’, G++ will accept your code, but allowing the use of an undeclared name is deprecated)
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::Write<CONT_STATE, WAIT_STATE, LAST_STATE>::writeByte(uint8_t)’:
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:240:41: error: ‘SPI0_PUSHR_EOQ’ was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:241:41: error: ‘SPI0_PUSHR_CONT’ was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:242:34: error: there are no arguments to ‘SPI0_PUSHR_CTAS’ that depend on a template parameter, so a declaration of ‘SPI0_PUSHR_CTAS’ must be available [-fpermissive]
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::writeWord(uint16_t)’:
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:247:107: error: there are no arguments to ‘SPI0_PUSHR_CTAS’ that depend on a template parameter, so a declaration of ‘SPI0_PUSHR_CTAS’ must be available [-fpermissive]
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::writeWordNoWait(uint16_t)’:
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:248:105: error: there are no arguments to ‘SPI0_PUSHR_CTAS’ that depend on a template parameter, so a declaration of ‘SPI0_PUSHR_CTAS’ must be available [-fpermissive]
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::writeByte(uint8_t)’:
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:250:106: error: there are no arguments to ‘SPI0_PUSHR_CTAS’ that depend on a template parameter, so a declaration of ‘SPI0_PUSHR_CTAS’ must be available [-fpermissive]
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::writeBytePostWait(uint8_t)’:
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:251:106: error: there are no arguments to ‘SPI0_PUSHR_CTAS’ that depend on a template parameter, so a declaration of ‘SPI0_PUSHR_CTAS’ must be available [-fpermissive]
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::writeByteNoWait(uint8_t)’:
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:252:104: error: there are no arguments to ‘SPI0_PUSHR_CTAS’ that depend on a template parameter, so a declaration of ‘SPI0_PUSHR_CTAS’ must be available [-fpermissive]
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::writeWordCont(uint16_t)’:
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:254:94: error: ‘SPI0_PUSHR_CONT’ was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:254:129: error: there are no arguments to ‘SPI0_PUSHR_CTAS’ that depend on a template parameter, so a declaration of ‘SPI0_PUSHR_CTAS’ must be available [-fpermissive]
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::writeWordContNoWait(uint16_t)’:
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:255:92: error: ‘SPI0_PUSHR_CONT’ was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:255:127: error: there are no arguments to ‘SPI0_PUSHR_CTAS’ that depend on a template parameter, so a declaration of ‘SPI0_PUSHR_CTAS’ must be available [-fpermissive]
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::writeByteCont(uint8_t)’:
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:257:93: error: ‘SPI0_PUSHR_CONT’ was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:257:128: error: there are no arguments to ‘SPI0_PUSHR_CTAS’ that depend on a template parameter, so a declaration of ‘SPI0_PUSHR_CTAS’ must be available [-fpermissive]
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::writeByteContPostWait(uint8_t)’:
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:258:93: error: ‘SPI0_PUSHR_CONT’ was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:258:128: error: there are no arguments to ‘SPI0_PUSHR_CTAS’ that depend on a template parameter, so a declaration of ‘SPI0_PUSHR_CTAS’ must be available [-fpermissive]
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::writeByteContNoWait(uint8_t)’:
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:259:91: error: ‘SPI0_PUSHR_CONT’ was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:259:126: error: there are no arguments to ‘SPI0_PUSHR_CTAS’ that depend on a template parameter, so a declaration of ‘SPI0_PUSHR_CTAS’ must be available [-fpermissive]
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h: In instantiation of ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::writeByte(uint8_t) [with unsigned char _DATA_PIN = 11u; unsigned char _CLOCK_PIN = 13u; unsigned char _SPI_CLOCK_DIVIDER = 6u; uint8_t = unsigned char]’:
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/chipsets.h:176:4: required from ‘void SM16716Controller<DATA_PIN, CLOCK_PIN, RGB_ORDER, SPI_SPEED>::clearLeds(int) [with unsigned char DATA_PIN = 11u; unsigned char CLOCK_PIN = 13u; EOrder RGB_ORDER = (EOrder)10u; unsigned char SPI_SPEED = 6u]’
Fast2Dev.ino:96:1: required from here
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:250:76: error: ‘SPI0_PUSHR_CTAS’ was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h: In instantiation of ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::writeByte(uint8_t) [with unsigned char _DATA_PIN = 11u; unsigned char _CLOCK_PIN = 13u; unsigned char _SPI_CLOCK_DIVIDER = 96u; uint8_t = unsigned char]’:
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/chipsets.h:119:4: required from ‘void WS2801Controller<DATA_PIN, CLOCK_PIN, RGB_ORDER, SPI_SPEED>::showColor(const CRGB&, int, uint8_t) [with unsigned char DATA_PIN = 11u; unsigned char CLOCK_PIN = 13u; EOrder RGB_ORDER = (EOrder)10u; unsigned char SPI_SPEED = 96u; uint8_t = unsigned char]’
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h: In instantiation of ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::writeByte(uint8_t) [with unsigned char _DATA_PIN = 11u; unsigned char _CLOCK_PIN = 13u; unsigned char _SPI_CLOCK_DIVIDER = 4u; uint8_t = unsigned char]’:
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/chipsets.h:63:4: required from ‘void LPD8806Controller<DATA_PIN, CLOCK_PIN, RGB_ORDER, SPI_SPEED>::showColor(const CRGB&, int, uint8_t) [with unsigned char DATA_PIN = 11u; unsigned char CLOCK_PIN = 13u; EOrder RGB_ORDER = (EOrder)10u; unsigned char SPI_SPEED = 4u; uint8_t = unsigned char]’
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h: In instantiation of ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::writeWord(uint16_t) [with unsigned char _DATA_PIN = 11u; unsigned char _CLOCK_PIN = 13u; unsigned char _SPI_CLOCK_DIVIDER = 6u; uint16_t = short unsigned int]’:
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:269:3: required from ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::writeBit(uint8_t) [with unsigned char BIT = 0u; unsigned char _DATA_PIN = 11u; unsigned char _CLOCK_PIN = 13u; unsigned char _SPI_CLOCK_DIVIDER = 6u; uint8_t = unsigned char]’
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/chipsets.h:175:4: required from ‘void SM16716Controller<DATA_PIN, CLOCK_PIN, RGB_ORDER, SPI_SPEED>::clearLeds(int) [with unsigned char DATA_PIN = 11u; unsigned char CLOCK_PIN = 13u; EOrder RGB_ORDER = (EOrder)10u; unsigned char SPI_SPEED = 6u]’
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:247:77: error: ‘SPI0_PUSHR_CTAS’ was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h: In instantiation of ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::Write<CONT_STATE, WAIT_STATE, LAST_STATE>::writeByte(uint8_t) [with ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::ECont CONT_STATE = (ARMHardwareSPIOutput<11u, 13u, 4u>::ECont)1u; ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::EWait WAIT_STATE = (ARMHardwareSPIOutput<11u, 13u, 4u>::EWait)0u; ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::ELast LAST_STATE = (ARMHardwareSPIOutput<11u, 13u, 4u>::ELast)0u; unsigned char _DATA_PIN = 11u; unsigned char _CLOCK_PIN = 13u; unsigned char _SPI_CLOCK_DIVIDER = 4u; uint8_t = unsigned char]’:
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:278:18: required from ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::writeBytesValueRaw(uint8_t, int) [with unsigned char _DATA_PIN = 11u; unsigned char _CLOCK_PIN = 13u; unsigned char _SPI_CLOCK_DIVIDER = 4u; uint8_t = unsigned char]’
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/chipsets.h:50:3: required from ‘void LPD8806Controller<DATA_PIN, CLOCK_PIN, RGB_ORDER, SPI_SPEED>::clearLeds(int) [with unsigned char DATA_PIN = 11u; unsigned char CLOCK_PIN = 13u; EOrder RGB_ORDER = (EOrder)10u; unsigned char SPI_SPEED = 4u]’
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:240:4: error: ‘SPI0_PUSHR_CTAS’ was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h: In instantiation of ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::Write<CONT_STATE, WAIT_STATE, LAST_STATE>::writeByte(uint8_t) [with ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::ECont CONT_STATE = (ARMHardwareSPIOutput<11u, 13u, 6u>::ECont)1u; ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::EWait WAIT_STATE = (ARMHardwareSPIOutput<11u, 13u, 6u>::EWait)0u; ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::ELast LAST_STATE = (ARMHardwareSPIOutput<11u, 13u, 6u>::ELast)0u; unsigned char _DATA_PIN = 11u; unsigned char _CLOCK_PIN = 13u; unsigned char _SPI_CLOCK_DIVIDER = 6u; uint8_t = unsigned char]’:
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:278:18: required from ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::writeBytesValueRaw(uint8_t, int) [with unsigned char _DATA_PIN = 11u; unsigned char _CLOCK_PIN = 13u; unsigned char _SPI_CLOCK_DIVIDER = 6u; uint8_t = unsigned char]’
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/chipsets.h:158:3: required from ‘void SM16716Controller<DATA_PIN, CLOCK_PIN, RGB_ORDER, SPI_SPEED>::writeHeader() [with unsigned char DATA_PIN = 11u; unsigned char CLOCK_PIN = 13u; EOrder RGB_ORDER = (EOrder)10u; unsigned char SPI_SPEED = 6u]’
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/chipsets.h:182:3: required from ‘void SM16716Controller<DATA_PIN, CLOCK_PIN, RGB_ORDER, SPI_SPEED>::clearLeds(int) [with unsigned char DATA_PIN = 11u; unsigned char CLOCK_PIN = 13u; EOrder RGB_ORDER = (EOrder)10u; unsigned char SPI_SPEED = 6u]’
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h: In instantiation of ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::Write<CONT_STATE, WAIT_STATE, LAST_STATE>::writeWord(uint16_t) [with ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::ECont CONT_STATE = (ARMHardwareSPIOutput<11u, 13u, 6u>::ECont)1u; ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::EWait WAIT_STATE = (ARMHardwareSPIOutput<11u, 13u, 6u>::EWait)0u; ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::ELast LAST_STATE = (ARMHardwareSPIOutput<11u, 13u, 6u>::ELast)0u; unsigned char _DATA_PIN = 11u; unsigned char _CLOCK_PIN = 13u; unsigned char _SPI_CLOCK_DIVIDER = 6u; uint16_t = short unsigned int]’:
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:318:5: required from ‘void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::writeBytes3(uint8_t*, int, uint8_t) [with unsigned char SKIP = 128u; D = DATA_NOP; EOrder RGB_ORDER = (EOrder)10u; unsigned char _DATA_PIN = 11u; unsigned char _CLOCK_PIN = 13u; unsigned char _SPI_CLOCK_DIVIDER = 6u; uint8_t = unsigned char]’
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:364:3: required from ‘void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::writeBytes3(uint8_t*, int, uint8_t) [with unsigned char SKIP = 128u; EOrder RGB_ORDER = (EOrder)10u; unsigned char _DATA_PIN = 11u; unsigned char _CLOCK_PIN = 13u; unsigned char _SPI_CLOCK_DIVIDER = 6u; uint8_t = unsigned char]’
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/chipsets.h:205:3: required from ‘void SM16716Controller<DATA_PIN, CLOCK_PIN, RGB_ORDER, SPI_SPEED>::show(const CRGB*, int, uint8_t) [with unsigned char DATA_PIN = 11u; unsigned char CLOCK_PIN = 13u; EOrder RGB_ORDER = (EOrder)10u; unsigned char SPI_SPEED = 6u; uint8_t = unsigned char]’
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:232:4: error: ‘SPI0_PUSHR_CTAS’ was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h: In instantiation of ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::Write<CONT_STATE, WAIT_STATE, LAST_STATE>::writeWord(uint16_t) [with ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::ECont CONT_STATE = (ARMHardwareSPIOutput<11u, 13u, 96u>::ECont)1u; ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::EWait WAIT_STATE = (ARMHardwareSPIOutput<11u, 13u, 96u>::EWait)0u; ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::ELast LAST_STATE = (ARMHardwareSPIOutput<11u, 13u, 96u>::ELast)0u; unsigned char _DATA_PIN = 11u; unsigned char _CLOCK_PIN = 13u; unsigned char _SPI_CLOCK_DIVIDER = 96u; uint16_t = short unsigned int]’:
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:318:5: required from ‘void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::writeBytes3(uint8_t*, int, uint8_t) [with unsigned char SKIP = 0u; D = DATA_NOP; EOrder RGB_ORDER = (EOrder)10u; unsigned char _DATA_PIN = 11u; unsigned char _CLOCK_PIN = 13u; unsigned char _SPI_CLOCK_DIVIDER = 96u; uint8_t = unsigned char]’
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:364:3: required from ‘void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::writeBytes3(uint8_t*, int, uint8_t) [with unsigned char SKIP = 0u; EOrder RGB_ORDER = (EOrder)10u; unsigned char _DATA_PIN = 11u; unsigned char _CLOCK_PIN = 13u; unsigned char _SPI_CLOCK_DIVIDER = 96u; uint8_t = unsigned char]’
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/chipsets.h:130:3: required from ‘void WS2801Controller<DATA_PIN, CLOCK_PIN, RGB_ORDER, SPI_SPEED>::show(const CRGB*, int, uint8_t) [with unsigned char DATA_PIN = 11u; unsigned char CLOCK_PIN = 13u; EOrder RGB_ORDER = (EOrder)10u; unsigned char SPI_SPEED = 96u; uint8_t = unsigned char]’
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h: In instantiation of ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::Write<CONT_STATE, WAIT_STATE, LAST_STATE>::writeByte(uint8_t) [with ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::ECont CONT_STATE = (ARMHardwareSPIOutput<11u, 13u, 96u>::ECont)1u; ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::EWait WAIT_STATE = (ARMHardwareSPIOutput<11u, 13u, 96u>::EWait)0u; ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::ELast LAST_STATE = (ARMHardwareSPIOutput<11u, 13u, 96u>::ELast)0u; unsigned char _DATA_PIN = 11u; unsigned char _CLOCK_PIN = 13u; unsigned char _SPI_CLOCK_DIVIDER = 96u; uint8_t = unsigned char]’:
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:328:5: required from ‘void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::writeBytes3(uint8_t*, int, uint8_t) [with unsigned char SKIP = 0u; D = DATA_NOP; EOrder RGB_ORDER = (EOrder)10u; unsigned char _DATA_PIN = 11u; unsigned char _CLOCK_PIN = 13u; unsigned char _SPI_CLOCK_DIVIDER = 96u; uint8_t = unsigned char]’
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h: In instantiation of ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::writeWord(uint16_t) [with unsigned char _DATA_PIN = 11u; unsigned char _CLOCK_PIN = 13u; unsigned char _SPI_CLOCK_DIVIDER = 96u; uint16_t = short unsigned int]’:
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:341:5: required from ‘void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::writeBytes3(uint8_t*, int, uint8_t) [with unsigned char SKIP = 0u; D = DATA_NOP; EOrder RGB_ORDER = (EOrder)10u; unsigned char _DATA_PIN = 11u; unsigned char _CLOCK_PIN = 13u; unsigned char _SPI_CLOCK_DIVIDER = 96u; uint8_t = unsigned char]’
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h: In instantiation of ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::Write<CONT_STATE, WAIT_STATE, LAST_STATE>::writeWord(uint16_t) [with ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::ECont CONT_STATE = (ARMHardwareSPIOutput<11u, 13u, 4u>::ECont)1u; ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::EWait WAIT_STATE = (ARMHardwareSPIOutput<11u, 13u, 4u>::EWait)0u; ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::ELast LAST_STATE = (ARMHardwareSPIOutput<11u, 13u, 4u>::ELast)0u; unsigned char _DATA_PIN = 11u; unsigned char _CLOCK_PIN = 13u; unsigned char _SPI_CLOCK_DIVIDER = 4u; uint16_t = short unsigned int]’:
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:318:5: required from ‘void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::writeBytes3(uint8_t*, int, uint8_t) [with unsigned char SKIP = 0u; D = LPD8806Controller<11u, 13u, (EOrder)10u, 4u>::LPD8806_ADJUST; EOrder RGB_ORDER = (EOrder)10u; unsigned char _DATA_PIN = 11u; unsigned char _CLOCK_PIN = 13u; unsigned char _SPI_CLOCK_DIVIDER = 4u; uint8_t = unsigned char]’
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:367:3: required from ‘void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::writeBytes3(uint8_t*, int, uint8_t) [with D = LPD8806Controller<11u, 13u, (EOrder)10u, 4u>::LPD8806_ADJUST; EOrder RGB_ORDER = (EOrder)10u; unsigned char _DATA_PIN = 11u; unsigned char _CLOCK_PIN = 13u; unsigned char _SPI_CLOCK_DIVIDER = 4u; uint8_t = unsigned char]’
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/chipsets.h:74:3: required from ‘void LPD8806Controller<DATA_PIN, CLOCK_PIN, RGB_ORDER, SPI_SPEED>::show(const CRGB*, int, uint8_t) [with unsigned char DATA_PIN = 11u; unsigned char CLOCK_PIN = 13u; EOrder RGB_ORDER = (EOrder)10u; unsigned char SPI_SPEED = 4u; uint8_t = unsigned char]’
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h: In instantiation of ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::writeWord(uint16_t) [with unsigned char _DATA_PIN = 11u; unsigned char _CLOCK_PIN = 13u; unsigned char _SPI_CLOCK_DIVIDER = 4u; uint16_t = short unsigned int]’:
/Applications/Arduino.app/Contents/Resources/Java/libraries/FastSPI_LED2/fastspi_arm.h:341:5: required from ‘void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER>::writeBytes3(uint8_t*, int, uint8_t) [with unsigned char SKIP = 0u; D = LPD8806Controller<11u, 13u, (EOrder)10u, 4u>::LPD8806_ADJUST; EOrder RGB_ORDER = (EOrder)10u; unsigned char _DATA_PIN = 11u; unsigned char _CLOCK_PIN = 13u; unsigned char _SPI_CLOCK_DIVIDER = 4u; uint8_t = unsigned char]’
