HI,
I am having some problems with autoleving function. No problem when doing test probe but after that when I go for probing Z axis touches the PCB at the first point and stops there, no further probing , also the the dots are disappearing from the window. I could manually move the machine after this with out resetting GBRL(0.9i)
There are 2 or 3 threads about it on forum. 2 weeks back
Hi Akhil, for the moment try it with http://chilipeppr.com/imania . It’s a forked version of the grbl workspace with a fix. Otherwise you might have to wait until it is fixed in the grbl workspace.
