Hi! I am just getting started with building my own lighting sculptures and I
Hi! I am just getting started with building my own lighting sculptures and I could do with your help. I am doing some tests with noise on APA102 white LEDs. I was hoping that by using white fixtures I could get good dimming but doesn’t seem to be that way. Maybe it is my poor implementation of the code? how could I se the noise example to produce smoother results?
Share your code, to see if you’re implementing it correctly.
I am trying out the example codes from the library. Anyway, here it goes. I really appreciate any advice
http://pastebin.com/0xkp2F5c
