my BOM so far what i put together from various posts. everything else i printed in ABS on a Replicator2x, already exceeded the 60hrs but nearly finished…
electronics:
Motor - Turnigy TrackStar Waterproof 1/10 Brushless Power System 4000KV/80A (Motor+ESC Combo) - HobbyKing #9192000061/25138
Servo - BMS-620MG High Torque Servo (Metal Gear) 9.1kg / .15sec / 50g - HobbyKing #BMS -620MG/8776
Radio - Hobby King GT-2 2.4Ghz 2Ch Tx & Rx - HobbyKing #HK -GT2/10608
LiPo: SLS XTRON 4000mAh 2S1P 7,4V 30C/60C Hardcase special buttom (http://stefansliposhop.de)
skrews (just an estimate get some more just in case)
Countersunk Head:
42x M3x8
8x M3x12
Pan Head Cap (or zylindrical):
14x M3x8
4x M3x10
6x M3x12
8x M3x16
6x M3x22
There is also a need of 22 M3 nuts.
beerings:
For the wheels you need 8pcs 4x5x10 (width x inner x outer diameter)
For the drivetrain you need 6 pcs 4x10x15 and 4 pcs 4x5x10 (when u use hsp-diffs s.b.)
For the steering you need 4pcs 4x6x12
Diffs etc. (if you dont want to print those):
3x HSP 02024 Diff Complete
2x HSP 02030 Drive Gear
2x HSP 02016 Universal Loint ( 1 pair )
5x HSP 02038 Ball Head screw
