Hi, I come from the 3d printing and Im finding difficult to find the
Hi,
I come from the 3d printing and Im finding difficult to find the CAM software, meaning the slicer of the milling machine.
Can you guys help me? I would like to find something that would work on Linux, I would like to avoid sketchup.
Thanks!
Thanks @Alex_Lee ​ I will give it a go.
By the way what is your setup software wise?
Inkscape to create SVGs. Then use http://jscut.org to create toolpaths. Then send over to ChiliPeppr.com and send to your CNC machine.
Thanks @jlauer ​ another great insight.
Thanks +Peter van der Walt​ but would to avoid Windows software
:stuck_out_tongue: it didn’t work so well for me last time I tried. But I will have a look again if you recommend
I prefer Freecad over Sketchup. It’ll run on Ubuntu. Then I shift-click all 3d objects and export to DXF to get a 2d representation. Then I use Cambam to generate toolpaths. Then take it to ChiliPeppr.
I like Freecad over Sketchup because Freecad is parametric and much easier to build up layers upon layers of 3d structures. I find Sketchup to lose structure really quickly on large drawings.
I’m also giving a try with freecad and I’m liking it a lot.
Look at http://www.makercam.com
Web based cam program. Also, cambam is linux capable
Thanks @Clockwerk_Mech ​, with all your help now I know the choices I have. Thanks!
Hmmm…I’ve had problems with FreeCAD (crashing bugs+wrapping my head around the UI), but perhaps I need to revisit it on my Linux box…
@SirGeekALot ​ there is that, but for me is one of the best CAD software for Linux.
I just started using http://onshape.com. it can export STLs. I’ve exported STLs for 3d printing. Still figuring out what to use for my ox
@Ricardo_Rodrigues ​ it does look like it may be a little bit better on Linux. I’ve had a hard time finding good tutorials on YouTube that work with the current version, v0.14. The UI changed quite a lot from v0.13. Also, default behavior seems to be different on Linux; e.g. rotating/orbiting an object. Also, the various workbenches really have me confused on where to start. I watched a good tutorial on constraints, but I am still scratching my head on how to get anything done.
@SirGeekALot I’ve also been using FreeCAD quite a bit under linux (until a few days ago when I started using onshape).
I started out with the youtube tutorials by bram de vries
https://www.youtube.com/user/boumdadaque/videos
This is Part 1: https://www.youtube.com/watch?v=xs1mFiJBYIo
So far, I’ve been using mostly “Part Design” (that’s where you can create sketches and Pad/Pocket) and then occasionally using the “Part” workspace for doing an Extrude (Pad adds to an existing part, extruder creates a new one).
I need to digure out using Draft and Sketches together (Draft has features like offset)
@dhylands Excellent tutorials! I am already through Part 5 and it is making much more sense now.
