Hi, i have a basic question.
Hi, i have a basic question. Is possible to connect and using LaserWeb with original “motherBoard” and firmware inside my CO2 40W machine? Or i must flash the firmware…? Thanks
No, it’s not possible
@Ariel_Yahni_UniKpty ok, and what minimum i must will do for it?
If you want the easiest path of upgrade then choose the http://cohesion3d.com board that’s designed specifically for that machine.
Or, dependent on the board you could give K40 Whisperer a try. http://www.scorchworks.com/K40whisperer/k40whisperer.html
I haven’t used it myself…but scorch’s other projects have always worked well for me.
