Hi, I have a problem with the Z axis homing.
Hi,
I have a problem with the Z axis homing. When I want to perform a homing Z-axis stepper is not working properly: does not rotate, but makes noise. Only after a few seconds turns several times with a great noise but not going to endstop. I tried to change the current and micro-steps with no effect. Z2 endstop is not connected and is defined as True. Where to find the cause? Can it be some conflict between max. speed for Z axis in printer.cfg (0.02) and homing speed for Z axis in default.cfg (0.1)? This is my printer.cfg for The Thing:
[System]
[Geometry]
Thing has H-belt
axis_config = 1
Set the total length each axis can travel
travel_x = 0.25
travel_y = 0.25
travel_z = 0.3
Define the origin in relation to the endstops
offset_x = 0.0
offset_y = 0.0
offset_z = 0.0
Stepper e is ext 1, h is ext 2
[Steppers]
microstepping_x = 7
microstepping_y = 7
microstepping_z = 7
microstepping_e = 7
microstepping_h = 7
current_x = 0.7
current_y = 0.7
current_z = 0.9
current_e = 0.9
current_h = 0.9
steps_pr_mm_x = 5.0
steps_pr_mm_y = 5.0
steps_pr_mm_z = 100.0
steps_pr_mm_e = 6.0
steps_pr_mm_h = 6.0
Set to -1 if axis is inverted
direction_x = -1
direction_y = 1
direction_z = -1
direction_e = -1
direction_h = 1
Set to True if slow decay mode is needed
slow_decay_x = 1
slow_decay_y = 1
slow_decay_z = 1
slow_decay_e = 1
slow_decay_h = 1
[Cold-ends]
connect-therm-E-fan-0 = True
connect-therm-H-fan-1 = True
[Planner]
Max speed for the steppers in m/s
max_speed_x = 0.2
max_speed_y = 0.2
max_speed_z = 0.02
max_speed_e = 0.2
max_speed_h = 0.2
[Heaters]
For list of available temp charts, look in temp_chart.py
Epcos 10 K
temp_chart_E = B57560G104F
pid_p_E = 0.05
pid_i_E = 0.01
pid_d_E = 0.01
ok_range_E = 2.0
Epcos 10 K
temp_chart_H = B57560G104F
pid_p_H = 0.05
pid_i_H = 0.01
pid_d_H = 0.01
ok_range_H = 2.0
Epcos 100 K
temp_chart_HBP = B57560G104F
pid_p_HBP = 0.05
pid_i_HBP = 0.01
pid_d_HBP = 0.01
ok_range_HBP = 4.0
Invert = False means endtop is connected as Normaly Open (NO)
[Endstops]
invert_X1 = True
invert_X2 = True
invert_Y1 = True
invert_Y2 = True
invert_Z1 = True
invert_Z2 = True
end_stop_X1_stops = x_cw, y_cw
end_stop_X2_stops = x_ccw, y_ccw
end_stop_Y1_stops = y_ccw, x_cw
end_stop_Y2_stops = y_cw, x_ccw
end_stop_Z1_stops = z_cw
[Homing]
home_x = 0.1
home_y = 0.1
First thing I would check is that both coils are wired properly. (Loose crimps, broken wiring, etc.) It sounds like only one coil is receiving current from the driver.
OK I check it out. I would add only that the engine is running normally outside the function Homing Z. Problems arise only when the Z axis homing operation begins.
Oh, if it runs normally outside homing, then that’s probably not a wiring issue :slight_smile:
Other things to consider are homing way too fast, or hitting a resonant frequency for the motor when you home. Different homing speeds may help.
