Hi. I have a request.
Hi. I have a request. Which I can set values ​​in Repetier when the printer delta does not print perfect circle, please?
Its your step count for the x y axiz. You need to do a calibration print mesure it and then adjust the steps. There is a step calculator in repetier to get you started.
It is Delta printer. Steps are right
Sorry didnt register that its a delta. Ive never set one up so unfortunately I can’t help much there.
check your three towers. are they the same distance from each other?
I have a delta printer. Can you describe the problem you’re having?
Ohfjb
O
Distance of towers aren’t the same ;-( I have a set values Radius error corection in repetier. But when I printed the circle so still has not an ideal shape
Not in the firmware. The real distance between each tower. check the diagonal between top tower A with bottom towerB should equidistant with top tower B with bottom tower A. In conclusion. Top A-bottomB=Top B-bottom A=topB-bottomC=topC-bottomB=topA-bottomC=topC-bottomA.
There are differences ;-(
Which delta printer do you have? Do you have Z end-stop adjustment screws you can turn to compensate?
I have a rostock printer own construction. All end-stops I adjust in repetier software
In theory, all three towers should be equal distance from the center at 120 degree apart. If one or more of these positions are off, then you will get ellipse instead circle.
Yes it is my case. Repetier should be able to compensate
