Hi, I have a weird problem, that is for certain related to the circuit.
Hi,
I am using a ESP8266 ESP07 to control 134 leds.
I have setup everything like program and wiring on the lab it worked.
Now i have changed cables to longer ones and the color do not work i get miss match of colors and lots of flickering.
My first thought was it was because i had two power supply’s so i switch to just use one… but still the same problem… when i have replaced all zero ground cables still the same problem…
But when i start probing with volt meter over ground cables i get the Correct color lighting and no flickering… switch the polarity of the probing cable and it gives the same problem as before.
So now to the questions;
What do the probing cable do, because a regular new cable do not fix the problem… and how can i mimic that in my circuit to fix this kind of problem?
Are you using a level shifter?
Nope i am not, do i need to use it?
The only thing i use is;
If the problem has started when the wires are longer, I suspect that a level shifter will help.
Try adding a few capacitors across the power and ground of the LEDs.
How long are the cables?
I would like to thank you all for helping me out, much appreciated!
The data cable was 1m , 45 cm led . 1m and then 45 cm led.
The 5V power cables was 1 m.
+Jeremy Spencer Special thanks that solved my problem, it was the level shifters that made my day!
Now i can go to sleep without thinking about this problem, got it for two days tinkering around both night and day :slight_smile:
This was the output i wanted
I have seen this guy on Instagram who uses one pixel next to the ESP-8266 to boost the data line, this booster pixel is not mapped in his patterns. I plan to try this tonight to see if it works on ws2812.
Saw that too but i had already cut and installed the led strip so i went for the shifter. But please keep me updated beacuse i am going for more projects like this :grinning:
@Giorgio_Salmi Good day sir! Can i ask for your code? i have very similar project with you that controlling led strips using esp8266. my problem is that there is delay to the respond of the leds. My thesis project is a basketball shotclock and time is very critical. Sir i need your help please thank you :slight_smile: here is the code of the receiver esp8266
#include “FastLED.h”
#define DATA_PIN 11
#define LED_TYPE SK6812
#define COLOR_ORDER RGB
#define NUM_LEDS 56
#define BRIGHTNESS 255
#define FRAMES_PER_SECOND 5
uint8_t pps = 4; // number of Pixels Per Segment
CHSV segON10(96, 255, 255); // color of 10s digit segments NOT TURNED RED
CHSV segON(96, 255, 255); // color of 1s digit segments
CRGBArray<NUM_LEDS> leds; /* CRGB leds[NUM_LEDS]; ← not using this. Using CRGBArray instead. */
// Name segments (based on layout in link above) and define pixel ranges.
CRGBSet segA( leds(pps * 0, pps - 1+(pps * 0) ));
CRGBSet segB( leds(pps * 1, pps - 1+(pps * 1) ));
CRGBSet segC( leds(pps * 2, pps - 1+(pps * 2) ));
CRGBSet segD( leds(pps * 3, pps - 1+(pps * 3) ));
CRGBSet segE( leds(pps * 4, pps - 1+(pps * 4) ));
CRGBSet segF( leds(pps * 5, pps - 1+(pps * 5) ));
CRGBSet segG( leds(pps * 6, pps - 1+(pps * 6) ));
int Na_set_na_Time = 24;
bool reset = false;
bool Stop = true;
char whatIsRead;
String inputTime;
#define PORT “1234”
String ssid = “Thesis”;
String IPADDRESS = “192.168.1.2”;
String PASSWORD = “12345678”;
int Na_received_na_Time = 24;
int count = 24;
#define ESP8266 Serial
//char buffer[512];
void setup() {
ESP8266.begin(19200);
delay(1000);
FastLED.addLeds<LED_TYPE, DATA_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
FastLED.setBrightness(BRIGHTNESS);
FastLED.clear();
pinMode(DATA_PIN, OUTPUT);
setUpWifiShield();
void loop() {
ShotClockTimer();
void setUpWifiShield() {
delay(3000);
ESP8266.println(“AT+CWMODE=1”);
delay(1000);
ESP8266.println(“AT+CIPMUX=1”);
delay(1000); //
ESP8266.println(“AT+CWJAP="” + ssid + “","” + PASSWORD + “"”);
delay(15000);
ESP8266.println(“AT+CIPSTART=0,"TCP","” + IPADDRESS + “",” + PORT);
delay(5000);
void ShotClockTimer() {
for (int count = Na_set_na_Time; count > 1; count-) {
setSegments(count);
//ESP8266.println(count);         //i comment nalng ni
for (int b = 0; b < 5;) {
  if (readingESP_SerialMonitor()) {
    processCommand(whatIsRead);
  if (!reset) {
    if (Stop) {
      FastLED.delay(200);
    } else {
      FastLED.delay(200);
      b++;
  while (count == 0) {
    //ESP8266.println(count); //comment ni dati
    if (reset) {
      resetTime();
      reset = false;
      Stop = true;
      return;
    } else {
      for (int x = count; x < 15; x++ ) {
        // dre mag CODE para sa  trigger
        if (reset) {
          resetTime();
          reset = false;
          Stop = true;
          return;
        FastLED.delay(205);
      reset = false;
      Stop = true;
      return;
  if (reset) {
    count = 0;
void processCommand(char comnd) {
switch (comnd) {
case 'Z':                     //start send Z
  Stop = false;
  reset = false;
  break;
case 'X':                     //stop send X
  Stop  = true;
  reset = false;
  break;
case 'Q':
  Stop = false;               //to reset, sample send Q14
  reset = true;
  break;
whatIsRead = ‘?’;
bool readingESP_SerialMonitor() {
if (ESP8266.available()) {
whatIsRead = ESP8266.read() ;
if (whatIsRead == 'Z' || whatIsRead == 'X') {
  return true;
} else if (whatIsRead == 'Q') {
  for (int i = 0; i < 2 ; i++) {
    inputTime += (char)ESP8266.read();
   //ESP8266.println(inputTime); //comment ni dati
  return true;
} else {
  return false;
} else {
return false;
void resetTime() {
Na_set_na_Time = inputTime.toInt();
//ESP8266.println("test - " + Na_set_na_Time); //comment ni dati
inputTime = “”;
void setSegments(uint8_t count) {
// Based on the current count set number segments on or off
uint8_t c1 = 0; // Variable to store 1s digit
uint8_t c10 = 0; // Variable to store 10s digit
uint8_t c;
CHSV segCOLOR(0, 0, 0);
if (count > 9) { // Split out 1s and 10s digits if count is greater then 9
c1 = count % 10;
c10 = count / 10;
} else {
c1 = count;
c10 = 0;
// ESP8266.print("count = “); ESP8266.print(count); // Print to serial monitor current count
// ESP8266.print(”\t 10s: “); ESP8266.print(c10); // Print 10s digit
// ESP8266.print(” 1s: "); ESP8266.println(c1); // Print 1s digit
// Operate on 1s digit segments first, shift them over, and then do the 10s digit segments
for (uint8_t i = 0; i < 2; i++) {
if (i == 0) {
c = c1;
segCOLOR = segON;
} else {
c = c10;
segCOLOR = segON10;
segA = segB = segC = segD = segE = segF = segG = CRGB::Black;  // Initially set segments off
if (c == 0) {
  segB = segC = segD = segE = segF = segG = segCOLOR;
if (c == 1) {
  segB = segG = segCOLOR;
if (c == 2) {
  segA = segB = segC = segE = segF = segCOLOR;
if (c == 3) {
  segA = segB = segC = segF = segG = segCOLOR;
if (c == 4) {
  segA = segB = segD = segG = segCOLOR;
if (c == 5) {
  segA = segC = segD = segF = segG = segCOLOR;
if (c == 6) {
  segA = segC = segD = segE = segF = segG = segCOLOR;
if (c == 7) {
  segB = segC = segG = segCOLOR;
if (c == 8) {
  segA = segB = segC = segD = segE = segF = segG = segCOLOR;
if (c == 9) {
  segA = segB = segC = segD = segF = segG = segCOLOR;
if (i == 0) {  // Shift segments over to 1s digit display area
  for (uint8_t p = 0; p < (7 * pps); p++) {
    leds[p + (7 * pps)] = leds[p];
}//end setSegments
