Hi, I have recieved one of those 2.5W laser diode+ XY chassis to do
Hi, I have recieved one of those 2.5W laser diode+ XY chassis to do some engraving.
Everything is fine except the diode is not firing.
When I plug it directly on the 12V power supply, it fire.
When I run the machine I got 12V on the output of the board but the diode don’t fire…
The board is a laseraxe-thing with an arduino nano.
I tried with various firmwares, various controller like benbox, laserweb 1&2. Same result.
On the other hand I have a spare azteeg x5 mini lying around. Can I control this kind of diode with it ?
Firing the laser will happen on a PWM output, that way you can control when on or off. If the machine came with the diode driver it must be connected to PWM. If you have a smoothie then go connect it to the Fan controlled or heater but mind that you need to configure LW2 with the correct parameter either M106/107 for fan or G0/G1 heater
Imgur
I suggest checking the outputs with a voltmeter. I think its common for boards not to switch 12v but to switch the ground line instead, so you would tie 12v to the diode + and connect the diode - to the switched output of the mosfet.
Thanks guys. I forget to change the Gcode commands to G0 G1 -_- It works now with the azteeg. Just some estep config to do and it should be fine. Thanks again !
