The K40 can cut 3mm Plywood in 1 pass, quite easily. Mdf by all accounts is easier to cut than the plywood, so there’s probably one or more things not set up correctly on your machine.
To REALLY put it right, a good quality set of mirrors, lens and air assist head are required.
The air assist head will shield your lens from smoke, debris, and allow you to fine tune the focus (a critical operation).
The mirrors are less important, but the stock ones don’t last well, and a good set of moly (arguably the most durable) mirrors will take routine cleaning with no harm.
Your pump should fill a 1 gallon jug 1/2 full in 1 minute (about 2 liters per minute) more flow is better. Water should never be allowed to become warm to the touch, add ice to the tank if needed, but even at high power, it normally takes hours to get the water that warm. (Use 5 Gallons minimum as a tank size)
Even the meager 30 watts of the K40 produces over a quarter million watts per square inch in a properly focused K40.
The most consistant power robbers are poor focus and poor mirror adjustment.
Start there. You should be cutting 3mm mdf at 1/2 power, maybe a little more if all is ‘dialed in’
No, it’s not practical to just install a 60w tube in a k40. It’s possible, just not practical, or usually required.
You would need a larger power supply, better mirrors, lens and head, not to mention a larger cabinet.
If you spend some time adjusting the mirrors dead on, and get the focus set just right (Aim for the center of the material if you’re trying for a 1 pass cut), I think you’ll find your 30watt K40 wakes right up and cuts surprisingly well.
Take it to “level 2” with an air assist head and fresh optics (see link)
it’s down right amazing.
Level 3 involves a longer focal length lens. I’ve found that a longer focal length lens makes for a great cutting combination on 3mm ply.
You’ll want 20mm Moly Mirrors Set of 3, and 18mm x 50.8mmFl ZnSe lens (fits new head)
If you want to try the longer lens, get an 18mmx62.5. They cut well, but are a touch less sharp to engrave with.
Saite cutter is a good source for the optics and have a great adjustable focus head.
http://www.ebay.com/itm/HQ-CO2-K40-Shenhui-Engraving-Head-Mirror-20mm-Focus-Lens-18mm-Integrative-Mount-/252563123459
http://www.floatingwombat.me.uk/wordpress/wp-content/uploads/2015/02/K40-Alignment-Instructions.pdf
