Hi!
I started to use elekslaser a3 and laserweb4. The engraving mode is working fine so far.
However, I’m having problems using the Laser Cut. Any help will be greatly appreciated!
First, I uploaded a SVG file of a square. It worked like expected. Then, I uploaded a map contour also in SVG format. The job started correctly but soon it kind of blocked.
Here is the beginning of the G-code generated:
M4
; Operation: 0
; Type: Laser Cut
; Paths: 5
; Passes: 1
; Cut rate: 1000 mm/min
; Pass 0
; Pass 0 Path 0
G0 X55.92 Y10.01
G1 X57.43 Y11.33 S192.00 F1000
G1 X57.83 Y13.33
G1 X58.77 Y15.12
G1 X59.90 Y16.78
Any ideas what is happening?
Thanks
https://drive.google.com/file/d/1rnBYA9YtdYsjdMjQalouAivwcnkchQC5/view?usp=drive_web
